I am new to OpenBuildings Designer and am looking for Euro Sections for steel modeling...eg IPE300, HE200B. I do not see a .mdb file under Structural Section File Manager that will provide me these sections. Is there an alternative .mdb that provides me access to these desired sections.
Edit because of T9 on smartphone :-) :
Please use the German (DIN/EN) environment. There you will find HEB and IPE profiles.
Scott,
You can find additional datasets in the following location.
C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_US\Data
I believe the the dataset you are looking for can be found in the EURO.xml file.
Dan Ruston
Hello Scott,
Please follow the wiki to know how you can load the section files.
Regards,Alifur
