Does anyone have any idea why there are always 3 copies of IFC/COBie definitions listed when creating new catalog items?
Hi Duncan,
Thanks for raising your issue.
Can you please share the XSD file containing the COBie definition in this share file link - https://bentley.sharefile.com/r-ref6bd06f55324fd1828e0da68ef11e40Also, run the data group system validator and check whether you have two same XSD files containing the COBie definition present in the Datagroup System folder?
Shivam Soni
Which file(s) from which location.
I am running the delivered ISO19650 Dataset with IFC extension enabled. These are the xsd files present in my datagroup system folder. None have been modified since installation
