I create some items in my catalog, on saving and closing, OBD starts looping through opening and closing windows. Seems to reopen the active file and then open then close ea ch view within the file for each new instance created in the catelog.
So bizarre
OBD 9.2
Hi Duncan,
Thanks for raising your issue,
Have you tried clearing the Prefs & then doing the same steps?
Resetting pref file appears to have stopped the looping Shivam
I had the exact same issue just now. Usually it only does it once (or the amount of catalog items that has been adapted). Now indeed also quite a few time. I'll try the reset of _prefs folder.
Had another issue today that's also related to preferences so I guess they are messed up for some reason.
