1) is there an easy way to convert an existing slab catalog to a single layer compound slab catalogor do I really start all over
2) my slabs catalog is ordered by object classification (BBSfB)the slabs are ordered well (BBSfB), compound slabs are not showing the BBSfB - what is wrong?
added: my slab.xml, a start of compoundslab.xml and the BBSfB xsd
OBD 9.2 win10
regards Rik
RikR said:1) is there an easy way to convert an existing slab catalog to a single layer compound slab catalogor do I really start all over
With the Datagroup Update Utility, every slab in the design file will be updated to a compound slab.
So I suggest you create a dummy file, place all the slabs you want to convert, then use this tool:
RikR said:2) my slabs catalog is ordered by object classification (BBSfB)the slabs are ordered well (BBSfB), compound slabs are not showing the BBSfB - what is wrong?
The images are not showing. How do you use the BB/SfB classification? As an actual classification I suppose? If so, I haven't had any issues assigning custom classification scheme to CompoundSlab. It works just the same as for all other element types.
These are the steps I have written down some time ago when adding my own classifications:
For each custom classification 4 steps need to be taken:
1. Create XML file with relevant information, Place them in dataset/Data/Classifications
2. Add to "ClassifiationSystemLookup.xml" in dataset/Data/Classifications
3. Add to Classificationsystem.xml in dataset/DataGroupSystem
4. Add to Objectclassification.xsd in dataset/DataGroupSystem
=> The custom classification will automatically be added to the "ObjectClassification" in the "Catalog Type Definitions"
I hope this can help you.
