Hi, we are using OBD (VERSION 10.08.00.44) for our project.
All this while the model is ok but suddenly the 3D Model illustration/smooth/transparents view are not showing properly,
Most of the 3D elements become lines (Slabs and column showing only lines in Illustration view, but in wireframe is okay.
Anyone knows whats going on? I can fix using TFRebuild key-in. but need to know why its happening, or else will keeps on happening in the future.
thanks
Hi Nur,
Thanks for letting us know about this.
Can you please try to rename your "Prefs" folder from this location: "C:\Users\User_Name\AppData\Local\Bentley\OpenBuildingsDesigner" and then restart your OpenBuildings Designer? Please refer to the screengrab below.
HTH!
Sayan Acharyya
hi, i ve tried deleting the files and its not working.
but, I hve replaced my datasets in my c folder and upgrade the dataset utilities and its working! Thanks for your reply .
You're welcome.
It's good to know that the dataset upgrade utility has helped you resolve the issue.
Regards,Sayan Acharyya
