Hello
Im still missing how to get transparency on glass when exporting to a IFC-model.It works with all other BIM software and its a bit embarrassing when joining BIMcoordination-meetings.Do you have a quick fix for this.I also tried it with the latest OBD and with only the delivered configuration...
Regars / Oskar
Thanks Alifur! I hope you'll get an answer how to resolve it.
Hello All,
Got an Answer, IFC 2*3 does not support transparency so you won't be able to see that in IFC.
IFC 4 does support transparency, but most of the IFC viewers does not support transparency as transparency is not a requirement for Coordination and Reference View certification. We have got an IFC viewer where it shows transparency properly. See the below image.
So its IFC viewers that is not showing the Transparency properly. i hope this helps you.
Regards,Alifur
Thank you
Now I can se that transparency from my export is ok in:Your Viewer ( I think )Dalux IFC ViewerBut no transparency when the IFC is opened in:SolibriNavisSimpleBimOpenBuildingsDesignerThe other programs shows transparency when the IFC is exported from Archicad or Revit.So i think something is missing in the IFC export from OBDI even opened a ICF made from Revit ( Made from competing office) in OBD and it looks great.I Used the ICF 4 exportCould you look in to this please
ODB EXPORT. Opened in Dalux Viewer
ODB EXPORT. Opened in ODB
REVIT EXPORT. Opened in ODB
Hello Oskar,
Can you please send me the Revit Export file & OBD export file so that i can test and report that to my dev team. If you have any issue then you can email me at : Alifur.mandal@bentley.com.
Thank you for sending the files, but the revit file that you have sent is only showing transparency in through the window and curtain walls. not through any walls or slabs.
