Hi All,
By using Open Building Designer, how can I link/insert Excel spreadsheet into Catalogue and show as 'link/file' in Properties? If it is not a correct way to do it in 'Catalogue', how to do it as long as the Excel can be link in the Properties.
After linked, can it be synchronize after editted the data in Excel?
Moreover, after I produce a schedule and open it in Excel, I found it unable to insert the equation/formula. May I know how to do it?
Thank you very much~~
After export the Excel and applied the equation, how do I synchronize the Excel back to OBD?
Hi Ting,
After doing the required equation you can use the option "Update from Excel" from Schedules tool to import (synchronize) those values back to OBD. Please refer to the below screengrab.
HTH!
Regards,Sayan Acharyya
Answer Verified By: Ting Wei Wong
