BIM Management 301: Installation and Upgrade Guide OpenBuildings Designer Version 10.09.02.36
I have installed OBD update 9 version 10.09.02.36 and while installing you may change the configuration to another drive on my network. Just followed BIM Management 301: Installation and Upgrade Guide OpenBuildings Designer on Bentley learn site. But when I followed the video of "Using the Configuration Explorer to Redirect the Default Seed Files" I couldn't use the "Configuration Explorer Connect Edition" because I get an error (I have created a service request for this, and it is under investigation). I want the Workspace split from the Worksets. Because I want the Worksets only for designers. And the Workspace only for the CAD manager. The app was good for version before 10.09.02.36. But now it doesn't work anymore. Which the configurations settings I have to change manually and which configuration settings I have to modify to split the Workspace and workset. Because when using the "Configuration Explorer Connect Edition", this will sets all automaticly. And it's now not woking well
Parents Reply Children
