Before I log a call for this, but has anyone else had errors like this with mirrored PS members in OBD?
Thanks for confirming, Tuan
I think we're referring to the same thing. In the video below, if you remove the stair from the equation the stringer is essentially a member following the stair's slope (placed at an angle) that is mirror-copied and its length changed/extended.
If this is the general idea, perhaps it was an issue in Update 8 - I've tried Update 9 and 10 - though I haven't found anything filed.
I'll put something together and upload it.
Sounds good. Thanks, Sean.
This is 10.08.00.44.
Original member on the right.
Left member is a mirror\copy of the first.
Use Modify Member End and, as you can see, the member rotates.
I have tested vanilla in newer versions and this issue does seem to be resolved.
I'll do some more testing and get back to you.
