Before I log a call for this, but has anyone else had errors like this with mirrored PS members in OBD?
It's good to know that Update 10 does seem to resolve the issue, at least in your initial tests. Let us if you see anything different along the way.
Same issue noticed on U8. mirrored PS members change the rotation of the profile when manipulated.
Windows 10 pro
OpenBuildings Designer Connect Edition Update 10.10.01.151
Hi Stefan,
I have checked U8 [and Update 10 also] and tried mirror-copy of PS element and I can see it showing mirror copy properly.
See image below
Do you see issue with any specific member ?
Possible to share dgn with problem element ?
Thanks and Regards,
Sandeep
Sandeep, the issue isn't the initial mirror. The problem occurs when you try to modify the mirrored member.
