Seems the centre lines of structural members are selectable regardless if they are visible or not. Took me a while to work out what's going on as I would have elements "randomly" selected when selecting other elements. In the snapshot below, I just hover my mouse over the invisible centre line and am able to select the member. Is there anyway to to turn this "feature" off? COG lines work as expected (non selectable when turned off).
Best regards,
Tuan Le
Can I please get an update on this issue?
Hello Tuan,
This item has been ended up as ADO Bug (Defect) item. I am going to share you the bug number shortly.
Thanks & Regards, Arindam Roy.
Thanks Arindam.
