Is it possible that someone can post some parametric doors and windows so I can use as a template for future elements.
Thanks in advance
James
See this link in Update 10 help....it explains (basically) how to create a parametric door cell...https://docs.bentley.com/LiveContent/web/OpenBuildings%20Designer%20Help-v6/en/GUID-D8DF5A62-3FED-441D-A2C9-7F8349AF8AB5.html
In the delivered MetroStation example WorkSpace/Workset there is a parametric cell library with some example doors.
Which Dataset is this part of? I'm using Dataset_NM and I don't have this workspace/workset.
