Since Updating to U10, my scaled custom linestyles that are defined in a RSC file with a UOR of 1000 are now displaying 1000 times smaller. See screen captures below.
When placing the same LS in the same model, I now have to scale them 1000 to look correct.
LS scale in the model are scaled using Annotation Scale.
Example of break line CLS not displaying correctly.
Image of what it looked like in U9 and earlier.
Hi Gary,
Just as a first step, does it make any difference if you key-in "linestyle set scale off" followed by "linestyle set scale on" and vice-versa?
Hi Steve,
Key-in "linestyle set scale off" followed by "linestyle set scale on" as you suggested has no affect.
Gary Manuel
OBD Update 10.10.00.197
Windows 10 Pro
Ah well, it was worth a try. i haven't seen any similar reports at this point. so perhaps it would be best to file a Service Request so support can test using your RSC file along with one of your DGN files.
That was my next step. This is problem for me.
I reverted back some machines to U9. I can't stay in this update with this not working like before.
