[OBD U9.2] Consecutive delete building features on structural members crash software
Not sure if this has been reported before. OBD seems to crash when I use the "Delete building features" tool on the same element twice. Attached is a sample file with 1 EA member that has 3 holes. Attempting use the "delete building features" to remove more than 1 hole on the member will make OBD freeze up and crash on my end, tested in example BuildingAU workset.
delete_building_feature_crash.dgn
  • Hi Tuan,
    Thanks for letting us know about this.
    We have also tested the same in OBD update 10 and the issue is reproducing. It looks to me like a bug. So, can you please file an SR so that we can attach that bug to the SR.
    But we have found a workaround for this. Please refer to the video attached.
    Sayan Acharyya
  • Thanks for the update Sayan. SR 7001508925 raised.
  • Hi Tuan,
    Also, on PS elements we can use shape properties options to delete those features.
    See image below
    HTH,
    Rg,
    Sandeep
  • Hi Tuan,
    You're welcome.
    Sayan Acharyya
  • Thanks Sandeep. Looks like that would be our work around for now. Just wondering any thing will be filed for this?
  • Hi Tuan,
    We have this bug filed Bug 1047412: Using "Delete building feature" to remove more than 1 hole at a time on the member is freezing OBD.
    HTH,
    Rg,
    Sandeep
Reply Children
