after updating to OB10 the Place Compound Slab doesnt have any options of whick kind of slab / catalogue Items to place. Otherwise the tool seems to work as normal, except there isnt anything to place. Can anyone please help me?
E
Hi Ellen,
Thanks for reaching out to us.
Can you please provide a screengrab while you are selecting the Compound Slab in OBD update 10?
Also, can you please let us know which dataset are you using?
Regards,Sayan Acharyya
Thank you for helping so promptly!
I use the danish DK dataset.
Thanks for providing us with the screengrab.
Please paste these attached Compound Slab XML files in this location: "C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_DK\DataGroupCatalogs" and then restart your OpenBuildings Designer.
HTH!
<?xml version="1.0" encoding="utf-8"?> <DataGroupSystem> <Version major="1" minor="0"/> <Units master="mm" sub="mm"/> <CatalogItems> <CatalogItem type="CompoundSlabLeaf" name="13 13 Ground Slab Undefined"> <Defaults> <Property definition="CompoundSlab_Leaf" name="CompoundSlab_Leaf/@Thickness"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="13::13 Ground Slab Undefined"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlabLeaf" name="13 13 Ground Slab, concrete"> <Defaults> <Property definition="CompoundSlab_Leaf" name="CompoundSlab_Leaf/@Thickness"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="13::13 Ground Slab, concrete"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlabLeaf" name="23 23 Floor slab and beams, concrete"> <Defaults> <Property definition="CompoundSlab_Leaf" name="CompoundSlab_Leaf/@Thickness"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="23::23 Floor slab and beams, concrete"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlabLeaf" name="23 23 Floor slab and beams, timber"> <Defaults> <Property definition="CompoundSlab_Leaf" name="CompoundSlab_Leaf/@Thickness"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="23::23 Floor slab and beams, timber"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlabLeaf" name="43 43 Floor surfaces"> <Defaults> <Property definition="CompoundSlab_Leaf" name="CompoundSlab_Leaf/@Thickness"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="43::43 Floor surfaces"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlabLeaf" name="43 43 Floor surfaces, tile"> <Defaults> <Property definition="CompoundSlab_Leaf" name="CompoundSlab_Leaf/@Thickness"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="43::43 Floor surfaces, tile"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> </CatalogItems> </DataGroupSystem>
<?xml version="1.0" encoding="utf-8"?> <DataGroupSystem> <Version major="1" minor="0"/> <Units master="mm" sub="mm"/> <CatalogItems> <CatalogItem type="CompoundSlabAssembly" name="Residential Floor Assembly"> <Defaults> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@Leaf" value="23 23 Floor slab and beams, timber"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@Thickness" value="350.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@IsCore" value="true"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@Leaf" value="23 23 Floor slab and beams, concrete"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@Thickness" value="75.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@Leaf" value="43 43 Floor surfaces"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@Thickness" value="12.5"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@EdgeSetback" value="150.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@EdgeLeaf"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="23::23 Floor slab and beams, timber"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlabAssembly" name="Single Layer"> <Defaults> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@Leaf" value="13 13 Ground Slab Undefined"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@Thickness" value="300.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@IsCore" value="true"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@EdgeLeaf"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="13::13 Ground Slab Undefined"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlabAssembly" name="Slab on Grade"> <Defaults> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@Leaf" value="13 13 Ground Slab, concrete"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@Thickness" value="100.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@IsCore" value="true"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@EdgeLeaf"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="13::13 Ground Slab, concrete"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlabAssembly" name="Tile Border"> <Defaults> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@Leaf" value="43 43 Floor surfaces, tile"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@Thickness" value="12.5"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@IsCore" value="true"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@EdgeSetback" value="300.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer1/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer2/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer3/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer4/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer5/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer6/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer7/@EdgeLeaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@Leaf"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@Thickness" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@IsCore" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@EdgeSetback" value="0.0"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@InfillEdge" value="false"/> <Property definition="CompoundSlab_Assembly" name="CompoundSlab_Assembly/Layers/Layer8/@EdgeLeaf"/> <Property definition="ObjectMaterial" name="ObjectMaterial/@PartDefinition" value="43::43 Floor surfaces, tile"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> </Defaults> </CatalogItem> </CatalogItems> </DataGroupSystem>
<?xml version="1.0" encoding="utf-8"?> <DataGroupSystem> <Version major="1" minor="0"/> <Units master="mm" sub="mm"/> <CatalogItems> <CatalogItem type="CompoundSlab" name="Single Layer"> <Defaults> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1PartDef" value="13::13 Ground Slab Undefined" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1Thickness" value="300.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsCore" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@ActiveLayer" value="0" isHidden="true"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlab" name="Slab on Grade"> <Defaults> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1PartDef" value="13::13 Ground Slab, concrete" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1Thickness" value="100.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsCore" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@ActiveLayer" value="0" isHidden="true"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlab" name="Tile Border"> <Defaults> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1PartDef" value="43::43 Floor surfaces, tile" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1Thickness" value="12.5" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsCore" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgeSetback" value="300.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@ActiveLayer" value="0" isHidden="true"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> <CatalogItem type="CompoundSlab" name="Residential Floor Assembly"> <Defaults> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1PartDef" value="23::23 Floor slab and beams, timber" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1Thickness" value="350.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1IsCore" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2PartDef" value="23::23 Floor slab and beams, concrete" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2Thickness" value="75.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsEnabled" value="true" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3PartDef" value="43::43 Floor surfaces" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3Thickness" value="12.5" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgeSetback" value="150.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsEnabled" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8Thickness" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8IsCore" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgeSetback" value="0.0" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8InfillEdge" value="false" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer1/@Layer1EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer2/@Layer2EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer3/@Layer3EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer4/@Layer4EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer5/@Layer5EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer6/@Layer6EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer7/@Layer7EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8PartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/Layers/Layer8/@Layer8EdgePartDef" isHidden="true"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@DirectionAngle" value="0.0"/> <Property definition="CompoundSlab_Application" name="CompoundSlab_Application/@ActiveLayer" value="0" isHidden="true"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@IsCombustible" value="false"/> <Property definition="ObjectFireResistance" name="ObjectFireResistance/@Compartmentation" value="false"/> <Property definition="ObjectSpaceBounding" name="ObjectSpaceBounding/@IsSpaceBounding" value="true"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsExternal" value="false"/> <Property definition="ObjectThermalTransmittance" name="ObjectThermalTransmittance/@IsBelowGrade" value="false"/> </Defaults> </CatalogItem> </CatalogItems> </DataGroupSystem>
Answer Verified By: Alifur Mandal
