hi. I don't know what to do anymore.I am doing visualization in OBD. She wants a white color for the wall. I made a fabric that is white. But there is always something that makes the wall gray - as attached.I turned off the environment, reflections, etc.I don't know what else can I do? thanks for the info.
Hi Tomasz,
It's hard to say just based on the image - are all the walls supposed to be white? What happens if you were to place a 2d shape that is white (no material, just element color) in the same area as these elements?
Hi Steve. I did such a test and the white element is grey.
Thanks for the answers. I have white materials - I checked it in various ways. In fact, the combination of light and intensity matters here. Below is the effect of the changes.
That certainly looks better!
thanks. I still have a problem with the boards on the terrace. The grain of the wood on the board is not in one direction.
Hmmm... I don't follow. In the image it looks like the grain is going the same direction for both sections.
I'm assuming the grain along the sides should be running along the length of the board, like the top? If so, how is the material image mapping defined?
