Here's another quirck with PFB in V8i;
I have a number of legacy PFB doors & windows matched to manufacturer product codes, that now do not display completely DEM Elevation extractions. Only the frame appears, so it is not the Cut Plan toggle, or the Set Opening Indicator toggles incorrectly set. I have applied different Parts and Symbology combinations withou there being any apparent effect on the output. The frame manifests in theh 3D model, in plan extractions and renders well enough, but not in elevation.
Any ideas out there?
Patrick Wilson
Hello, Patrick,
It is difficult to tell the source of the problem without the design file(s). My recommendation is to log a problem with our support group and include the DGN and version of Bentley Architecture and MicroStation you are using. That should get you the fastest results.
Sincerely,
Steve Stevens Product Manager - Bentley Archtiecture
Brian Thomas, AIA, LEED AP BD+C
GH2 Architects
Brian,
Did you get any response to your ST ?
Patrick Wilson RIBA
Has this been fixed?
