I have created a series of Parametric components and linked to Datagroup catalogs and am encountering several errors and issues.
1. when placing the catalog item, the components are placed on the active level - if I drop the component then the geometry resorts to the intended part/family - strangely though when exported to IFC the mapping is correct?
2. I place the component on the face of a wall, but when completing the placement the component attaches to the inside face and hence orientates itself 180° from intended orientation. there is no option to rotate on placement
3. updating Objects is extremely difficult as per another post i have already made. the catalog defintions do not want to update after updating the parametric cell definition.
Hi Duncan,
Thanks for letting us know about this.
Can you please share a short video of the workflow? It will be helpful for our further investigation.
Regards,Sayan Acharyya
