Hello, it seems that the Quantify tool does not generate any excel file. My OBD version is 10.09.02.36.I have done a test with simple elements from the Dataset_NM catalog (a brick wall and a steel column), and when selecting Quantify, it does not give any error but it does not generate the XLS file either.Thank you
Hi Sergi,
Can you please try to repair your Microsoft 365 Apps from your Control Panel under Programs and Features and then try to use the Quantify tool? Please refer to the screengrab below.
Please do let us know about the outcome.
Regards,Sayan Acharyya
Answer Verified By: Alifur Mandal
Yes! that was the problem.
Thank you Sayan
Sergi Ferrater
Good to know that the provided resolution helped you to moved forward regarding the Quantify tool.
