How can I delete or edit a workspace in OpenBuildings? It seems that I use the wrong root when I created a new workspace and as a result I can't see the worksets.
Hello Chris, You need to do clean reinstallation of OpenBuildings Designer application. You can go through these wikis for reference -
Thanks & Regards, Arindam
Answer Verified By: Steve Cocchi
Hello Arindam,
Thanks for your help! Appreciate it!
Hello Chris,
You are welcome! I hope now you are getting right Workspace and Workset.
Thanks & regards, AR
