"Publish i-model failed - Revit API"
  I cannot export the imodel from Revit 2020. The models have been upgraded from Revit 2018. Any idea what can it be? Many thanks.
  • Hello Maria,
    For more details, you can share the ExportDWG.dll.log.xml file here. Will check at my end.
    Thanks & regards,
    Arindam Roy
  • Hello Maria,
    Can you please tell us whether you have also updated Revit 2018 to revit 2020? Because the imodel plugin that was created for revit 2018 should not work for Revit 2020.
    Alifur
  • Hi Alifur,
    The Bentley iModel plugin is created for 2020 in which Maria is facing the issue.
    Also attached ExportDWG.dll.log.xml
    Currently there are 3 users who are facing the issue perhaps there might be more depends upon projects
    Ashutosh Patil
    <?xml version="1.0" encoding="utf-8" ?>
    <configuration>
        <configSections>
            <!-- See http://logging.apache.org/log4net/release/config-examples.html -->
            <section name="log4net" type="log4net.Config.Log4NetConfigurationSectionHandler, log4net" />
        </configSections>
        <log4net>
            <appender name="RollingFileAppender" type="log4net.Appender.RollingFileAppender">
                <file               value="${USERPROFILE}\\Application Data\\Bentley\\Logs\\Revit.SaveAs.Bentley.imodel.log" />
                <appendToFile       value="true" />
                <rollingStyle       value="Size" />
                <maxSizeRollBackups value="10" />
                <maximumFileSize    value="1000KB" />
                <layout type="log4net.Layout.PatternLayout">
                    <param name="ConversionPattern" value="%date [%thread] %-5level - %logger - %message%newline"/>
                </layout>
                <!-- Filter only i-model Plugin logs: -->
                <!--filter type="log4net.Filter.LoggerMatchFilter">
                   <loggerToMatch value="Revit.ExportDWG" />
                </filter>
                <filter type="log4net.Filter.DenyAllFilter" /-->
            </appender>
            <appender name="ConsoleAppender" type="log4net.Appender.ConsoleAppender">
                </layout>
            </appender>
            <appender name="ColoredConsoleAppender" type="log4net.Appender.ColoredConsoleAppender">
                <mapping>
                    <level value="ERROR" />
                    <foreColor value="Red, HighIntensity" />
                </mapping>
                <mapping>
                    <level value="WARN" />
                    <foreColor value="Yellow" />
                </mapping>
                <mapping>
                    <level value="INFO" />
                    <foreColor value="White" />
                </mapping>
                <mapping>
                    <level value="DEBUG" />
                    <foreColor value="Green" />
                </mapping>
                    <conversionPattern value="%date [%thread] %-5level %logger - %message%newline" />
                </layout>
            </appender>
            <appender name="DevStudioOutput" type="log4net.Appender.TraceAppender">
                <!-- Sends output to Trace output which will show up in DevStudio's "output" window -->
                </layout>
            </appender>
            <appender name="DebugView" type="log4net.Appender.OutputDebugStringAppender">
                <!-- Can be used with http://www.sysinternals.com/Utilities/DebugView.html -->
                    <param name="ConversionPattern" value="[%thread] %-5level - %logger - %message%newline"/>
                </layout>
            </appender>
            <root>
                <!--level value="WARN" /-->
                <!--level value="INFO" /-->
                <!--level value="DEBUG" /-->
                <!--level value="ALL" /-->
                <appender-ref ref="RollingFileAppender" />
                <!--appender-ref ref="ColoredConsoleAppender" /-->
                <!--appender-ref ref="ConsoleAppender" /-->
                <!--appender-ref ref="DevStudioOutput" /-->
                <!--appender-ref ref="DebugView" /-->
            </root>
        </log4net>
    </configuration>
  • Hello Ashutosh,
    Have you tried to repair the plugin? Also that plugin has been discontinued from our side. So if there are many users who are facing the similar issue then try to follow this to itwin referencing method to create the imodel files.
    Product: OpenBuildings Designer Version: CONNECT Edition Area: Interoperability Subarea: Revit The Situation Do you need to reference a Revit model…
    Alifur
  • Hi Alifur,
    Thanks for the info but moving to above workflow is not possible with current ongoing project in which user is working.
    Also the issue has been resolved by just resintalling Revit 2020.
    Ashutosh Patil
