I would like export an electrical model to Microstation from Revit. The Revit DGN export is not exporting in 3D, cable trays are only shown as 2D lines, fittings or fixtures are not exported at all.
Is there any method to export electrical families so I can use those in Microstation?
Thank you!
ZoltanYou should post this in the OBD forum.
However, Revit CANNOT export to a 3d DGN, it can only export to 2d DGN. To do this you will need to export via IFC. and then import then IFC into your DGN file
HTH
