Transparancy Threshold on elevation view (dynamic) ignored when printing
I have a Drawing with a Dynamic View attached, this is an elevation view using the Forward Drawing Display Style to show the forward graphics.
Part of the building facade is a material (Part with a glass material attached).
When changing the Transparency Threshold value in the Forward Drawing, I can see the effect, changing the appearance of the DV in the Drawing (see screenshot 1 vs 2: 0% vs. 100%).
However in the print (see screenshots) it doesn't change, making both print as if you look through the mentioned material.
How can I print these correctly (so no transparancy), without having to change from Dynamic to Cached mode on the DV reference?
