how to disable part centerline in openbuildings designer in such a way that when using the select multiple elements the center of a part is not detected
I do not need to show half op the part width
Hi James,
I tried to replicate the issue here at my end. However, it worked as expected. Please check your dim style settings, e.g-
Otherwise try to reset the dimension style and restart the application.
HTH!
Regards,Sayan Acharyya
