how to disable part centerline in openbuildings designer in such a way that when using the select multiple elements the center of a part is not detected
I do not need to show half op the part width
Hi James,
The Part Centerline is coming from the Family/Part editor and then Centerline Symbology. Untick the centerline toggle and see if that fulfill your requirements.
Regards,Sayan Acharyya
I think what you are seeing is a bug in OBD, bug 1052353. Previous discussion here:
https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/238290/obd-u9-2-36-invisible-centre-lines-of-structural-members-are-selectable
Best regards,
Tuan Le
Hi Sayan I have the the centerline toggle unticked, used another wallpart with yhe same result
Is it possible it has to do with the level on which it's resided? The centerline (cntr)?
Hi James, I can't see your first picture and can't see how do you place your dimension. Could these video help here?
