when I make a floorplan and use the select multiple element tool in the dimensions tool it caches the center of the wall
So i get the dim of halve on each side in the dimension line
any help will be appreciated
James
Hi James,Can you please give us a screengrab of the issue? And which OpenBuildings Designer Update you are currently using?Regards,Shreya
