how to disable part centerline in openbuildings designer in such a way that when using the select multiple elements the center of a part is not detected
I do not need to show half op the part width
Hello James,
The Part Centerline is coming from the Family/Part editor and then Centerline Symbology. Untick the centerline toggle and see if that fulfill your requirements.
Regards,Alifur
