Is it possible to create a section view, using the section call out tools, that has an angle in it? I'm aware you can add a step or a gap in a section but not too sure if it's possible to have an angle.
As an example, would it be possible to create 1 section along the dashed line?
Not that I'm aware of. For that kind of output, I normally just create 2 sections then clip and superimpose them.
Hi Davulsukur,I don't think currently we have any feature like this. You can add your request to our Idea Portal page so that the concerned team will look into it. Regards,Shreya
Yeah, that's what I've done in the past. Was hoping there might be a better solution but I'll stick with that.
It would also be usefull to make certain parts of a plan section cut higher than the main cut plane, for example if parts of the floor are higher than others.
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
Hi Stefan, that sounds like the "create step" function:
https://docs.bentley.com/LiveContent/web/OpenBuildings%20Designer%20Help-v7/en/GUID-06F18C15-5192-C6DC-4E02-F058CBBF24C6.html
