when I create a new work set the floor manager is blank and unable to take any entries. In the message center I get this:
"Architecture Configuration Check found error(s), please set _BB_SHOW_DATASET_LOAD_MSGS configuration variable and restart to see details."
Is this related to the problem with Floor Manager? IPlease help me.
Hi Ellen,
Can you please let us know the version of OpenBuildings Designer you are using?
Also, it would be helpful if you can provide a screengrab of the error!
Regards,Sayan Acharyya
It is version 10.
Can you please try to use the "Add Building" option under Floor Manager and then see if it is getting created or not?
Yes, of course. That was the first (and only) thing I tried. No response, then I called for help.
maybe I'm looking to far, but it might just be that you are having the same problem that I was having. What is the language of your windows installation? When mine was in Dutch I had a lot of issues with grid/floor manager.
I sincerely hope your issues have another cause, but wanted to put it out there since it might not be the first thing Bentley support will look for.
