I noticed that "Add Data" tool allows to change series of parameters. It is possible to fill parameters only if object doesnt contains instance data. I have tried with solids.
What if my Solids have a lot of instance data, and I want to change the value one of them?
For example how to change this value from 88 to 66?
Adrian
Select Geometry-> right "click" -> "Modify Instance data"
