When I open an IFC file in a BIM viewer, I cannot access task information.
How can I insert the IFCTasks information in the IFC file so that I can visualize it in the properties of the objects when I open it in BIM visualization software? Ex: BIMCollab, Dalux and usBIM
Hello Bruno,
You need to edit the information inside the authoring file itself then only those properties will show in the IFC file, IFC files are non editable and also the application you are mentioning is IFC viewers that only visualize the IFC file.
Hope this helps you.
Regards,Alifur
