I used to be able to easily customise my right click pop up context menu. I have tried in OBD Connect and despite pointing to the .dgnlib file there is no way of customising the context menu. I just get the same little folder structure every time. So unless it's hidden in there the one to use? I have gone through the config variables editor to try and get it to point to the file but still no use.
Anyone got an idiot's guide to let me know how to do this. I was simply wanting to add "delete fence contents" onto the pop up menu...
Hello Keith,
The ribbon customization you are looking for gets stored inside the Personal.OpenBuildingsDesigner.dgnlib. Try to purge the user cache folder and try to create context menus.
Thanks & Regards, AR
Hi Arindam, thanks, I opened that file and the place where in previous versions allowed me to drag tool onto the context menu shows limited information. To be clear it is the right click pop up menu I am trying to add to. Concerned about purging anything in case I lose all me interface arrangements.
I have said on more than one occasion to Bentley that this really should be waaaaay easier without having to dig around to find where these things are hidden.
Keith
