I'm adding custom catalog items to my OBD build, but when I go to select the section name I want to use, my shape file isn't showing:
I can find and access members when modelling:
Any reason this would be happening?
OBD 10.08.00.44
Will do Steve, thanks. In the meantime, I've managed to edit the catalog files externally with the correct member sizes and that seems to work.
Thanks, Bear, for the update. I was just thinking about to check the status.
Regards, AR
