In OBD U9 version 10.09.01.38 the structural quantities for a double angle member appear to be incorrect. Is there a way to fix this or has this been resolved in update 10?
Hi Ruston,
Thanks for letting us know about this.
Can you please specify which structural quantities for the double angle member seems to be incorrect? It will be helpful for our better understanding and investigation.
Regards,Sayan Acharyya
The weight of the member is incorrect.
Apologies for the delayed response.
We will have some discussion with our Dev team regarding this and will update you accordingly.
What's the status of this issue?
I have raised a new case (CS0058955) on your behalf and I'll provide you further update from that case.
Thank you, keep me posted.
Sure will let you about our findings.
Regards,Sayan
