SmartLine has changed color to red. In the p roperties it shows as locked. I select unlock and it will not unlock. How can I unlock the line?
Hi Gina,
No worries!! I have received your file and below are my findings.
When I opened the file and opened the Properties of the line you mentioned I can see that the line is "Unlocked". Please refer to the screengrab below.
After that I chose the line and opened the Level Manager and changed the color of the line to say- blue for example and the process was successful.
Can you please try the same at your end and let us know about the outcome?
Regards,Sayan Acharyya
I have approved your posts.
See also: Communities Secure File Upload
When I opened your file I can see the line you mentioned so I selected the line and opened the Properties dialog box and noticed that it was "Unlocked". Please refer to the screengrab below.
Then I opened the Level Manager and changed the color of the line say blue (in this case) and saw that the operation was successful.
So, can you please try to do the same at your end and let us know about the outcome.
Previously you have sent an OneDrive link to download the file.
