SmartLine has changed color to red. In the p roperties it shows as locked. I select unlock and it will not unlock. How can I unlock the line?
Yes. I have been replying to you. Thanks for your help but the I was having issues with another line. Not the one you selected.
Hi Gina,
Thanks for pointing out the correct lines.
When I selected one of the lines I can see that in the Building Element Info it is showing Unlocked but when I opened the Properties dialog box it is showing Locked... not sure what's going on with these lines. Please refer to the screengrab below.
But then when I selected the line and from Level Manager changed its color to green (in this case) it changed.
Let me have some discussion with my team regarding how to unlock these lines and I'll update you accordingly.
Regards,Sayan Acharyya
You're welcome.
Regards,Sayan
Can you please let me know whether you are opening the file from ProjectWise or local machine?
