VBA Error at start up
When I start the beta I get this VBA error:
 Picking debug produces this:
What does the mvba do? This is running on a Vista machine, might there be any permsissions issues connected with this vba? I had the same issue with the V8i CR. My workaround was to rename rejectautoopening.mvba to stop it running which at least let me into the application.
  • Interestingly enough, I just followed up with another user who was getting the same error.  Maybe that response will help here as well...
    There are system level files that Architecture relies on for using VBA and for Office integration which MicroStation may not. I was able to dig up a few potential solutions, both from our internal database and from general Google-ing:
    1) Try reinstalling the required MicroStation Prerequisite Pack. If this does not correct the issue, also try ininstalling and reinstalling the vertical application (BA) as well.
    2) The Microsoft® Scripting Runtime nay need to be installed from the Microsoft® Windows Script components. The Microsoft® Windows Script components are installed by a self-extracting EXE. Please download and install the Microsoft® Windows Script Installer at the following Microsoft® Web site:
    http://msdn.microsoft.com/library/default.asp?url=/downloads/list/webdev.asp
    This link may also bring you directly to the download:
    http://www.microsoft.com/downloads/details.aspx?FamilyId=C717D943-7E4B-4622-86EB-95A22B832CAA&displaylang=en
    3) Try re-registering Office applications such as Excel. To re-register Excel, in the Windows Run dialog box, type C:\Program Files\Microsoft Office\Office\Excel.exe /regserver and press OK.   Note: The path specified may change based on your operating system and Office version.
    4) Registry errors could be involved. You can try downloading a reputable Registry Cleaner to see if it picks up any errors.
    In the end, this error typically indicates that some Windows level file(s) is either not installed correctly or is missing altogether.
    HTH
Reply
    HTH
