Is there any way to design prefabricated structures using the library components in Open Building Designer software?
Thanks for your response.
I'm doing my project work on prefabricated structures, and for that, I want to create components (walls, columns, beams, etc.). Are there any library components available in the Open Building Designer software?
OBD has the ability for you to create components from the parts (walls, columns, beams in steel, concrete, wood, plastic, glass or in combinations of any number of parts)
Once you have created these components you can save them for future use as either dgn files, cells, compound cells or assemblies. These would then be the library.
There may be manufacturers who use OBD but I am not aware of any who have made available there specific library of components to make prefabricated structures for obvious propriety copyright reasons.
Again if you were a little bit more specific as to what you are wanting to achieve then people on this forum may be able to help
Ian
currently using OBD 10.10.01.151
