I think there is a little bug with the above command.
When I have a model I use the icon "Floor Plan View". Then I try the icon "Create Building View & Drawing". This works nicely except when I tick the option Open Drawing: the sheet is opened and is OK but when I go back to my model the clip volume is no longer applied.
Can you reproduce this?
Thanks for looking into this,
Luc Dierick
Very true!
I've thought of another potential reason why the current behavior is what it is... Since you've creating a new Building View model, the intention is for *that* model to become the focal point, not the main 3D model.
If the 3D model were to remain the area of focus, you could always place the Plan view and *not* generate the external BV model until needed for plotting or other post-processes. More or less what Sean is describing in the "Need Help! moving from V8XM 2-way workmode to V8i" thread below.
