OBD Update 10
I've been trying out some windows.
For some reason, some of them appear transparent, but others do now.
I've tried changing the glass type (many times) in the property panel. Including to a glass type that does show up transparent in some of the other window types.
But it is still not transparent. Any clues as to why?
Aslo, ..... somewhat oddly/confusing, ....... When you use the 'Place Window' tool the F+P keeps often changes when you choose a different window type (Example | Fixed, AL | DoubleHung, ...)
Sometimes the Part is 'Default Window Frame', .... then 'Window Frame Steel' ...... then just 'Window' ....... in a somewhat random manner. When the 'Part' changes, so does then the 'Level' that the window is placed on.
I can't see any reason or logic to this inconsistency.
Hi Danny,
Thanks for letting us know about this.
I tried to place different kind of windows in my model using OBD U10.1 and the transparency is working fine at my end.
Can you please try to repair your OBD by following the wiki link below and do let us know if the issue gets resolved or not?
HTH!
Regards,Sayan
Hello
I've tried this but it hasn't done anything
Some of the windows are fine. But others not
Could you try the window 'x_Fixed with Frame' for example
Danny Cooley
Freelance AEC CAD/BIM Technician Architecture, MEP & Structural ..... (& ex Low Carbon Consultant, ..... because they weren't that bothered!)
OBD Update 10, Windows 10 Pro, HP Z4-G4, 64Gb, Xeon 3.6GHz, Quadro M4000
NM dataset, right? If so, I seem to be getting the same results.
It seems to be the part assigned to the windows that is causing the issue. I changed a window's glazing part (Glass 6mm) to one used by a door (Glass-Float 6mm) and that seemed to work. The part(s) in question use the material "Grey glass no refract" which appears to be missing from the palette Glass&Plastic palette. So I changed Glass 6mm's material to "Grey glass refract" instead and the windows using that part now had transparent glazing.
Can create a new Case with support so we can get this into the system?
Regards,Steve Cocchi
Hello there
Yes, it's the NM Dataset
Yes, ... I figured that the Part assignment had something to do with it.
Did also see that 'Grey Glass no refract' was missing from the Glass and Plastic material palette (which makes one wonder how that assignment was made in the first place. Possibly left over from a previous version of the software, and then the palette got updated separately).
What has also been puzzling, is that I tried changing the material assignment to 'Clear Glass', which worked on some of the other windows.
I then have some windows that I changed to 'Glass 6mm' which do indeed work!
Anyway, I'll create a Service Ticket so this can be examined properly
Must say though ......
I've been testing out/trying out Update 10 over the last few weeks now.
SORRY, ... BUT I HAVE TO COMPLAIN ...... there are numerous such issues.
Basically things that just haven't been checked .... at all seemingly ...... Datagroup Types that don't have some definition correctly set/associated, Levels that get stuck ON or OFF (the Level Display Dialog can't turn them OFF!), .... Compound Walls that don't behave correctly, Schedules just disappearing, conflicts between, Casework not re-sizing properly, Previews sometimes missing in the 'Place Window/Door/Item/ .....' tool, conflicts between the DrawingSeed.dgnlib and the seed file that is used in the Windows Open Dialog Box, Drawing Rules not working ... Umpteen problems with the 'Drawing Production' workflow ....
In this instance ....... there are something like 40 window types available.
Well, .... someone creates a wall, then places those 40 or so windows and checks that they 'work' correctly!
That really isn't too much to ask!
This has been one of the main problems ....... for many years. What ever system Bentley has in place for checking/testing the software BEFORE it's released, I'm sorry to say, ...... but it has to be said, simply isn't up to it.
I've got a long list of issue here, and that is just predominantly with Architecture. I haven't even started (properly) yet, on the Structural, MEP ..... Energy Analysis, GC, Visualisation, Lumen RT, iTwin (a few issues there I've come across already) ..... and there's plenty of tools/features in the Architecture that I haven't delved in to yet: Named Presentations, Item Types, Components Centre, Constraints Modelling, Surfaces, Meshes, Named Boundaries ....
Seemingly half to tools/features I haven't even really looked at yet, and I've already got a long list of issues (that's before I get to Structural, then MEP)_
Just how many days (yes days and days, .... which can turn in to a few weeks) do Bentley Systems expect us to spend pickin gout all these 'issues'?
These are not related to some very advanced, never been done before workflow ..... nesting Level 6 with some obscure file formats, linked to some analysis, feeding to some spreadsheet, which then feeds back to the modelling software, ... ect ..
This is brand new, straight out of the box, bog standard (fairly simple and straightforward) BASIC BIM modelling, with only native Bentley objects/components and files ......
We are now on version 10 (yes 10) of the Dynamic Views workflow and the results and still unacceptable and unreliable.
In anything approaching real world use, the so called 'automated production' of drawings soon breaks down and there will be constant (yes contant) need for 'manual intervention', often involving having to open the Saved View, then the Drawing Model, then the Sheet, ...... 3, 4, ...5 times before it looks (more or less) like it' supposed to.
Bentley, ...... we are all tired of this (many of them got beyond tired of this many years ago ...... and went over to some 'other software' ..... not mentioning any names for now).
I must be blunt (time is of the essence here), if they seriously want to regain some ground in the Buildings Sector, then this whole quality control/checking/testing needs to be seriously overhauled and improved ......
Rant over for now (but rest assured ....... I'll be back)
Meantime, I will log a ticket
Sorry for (yet another) delayed response. I would suggest filing support Cases for whichever issues you feel are most critical. That way we can test against our latest internal builds. We're not that far off from the next release so it's questionable what can be fixed in time, but step one is to test and get some defects filed where applicable.
