When I create a clip volume in OpenBuilding, the cut settings doesn't present well. I have open the same filt with Bentley View and here it is better. See my image. On the left side a Bentley view and the right side OpenBuilding,
Have create a new case, but doesn't get any solution.
Hi Andy,
Thanks for filling a new case on this issue. It seems better and convenient to check the dgn file through a case. Could you please share the case number so that I can ]have a look at the issue ?
Best Regards, Arindam
Hello Arindam,
It was a long ago. Was a Service Request and date was 01 May 2023. And I don't know which SR number it was. But I have also send an screenshot. That is the same issue. And it's not solved. I know develop team will solve this, but don't have the time I think. I thought OpenBuilding is a microstation based Cad software.
Best regards,
Andy
The case is now CS0102516 en handled by Shreya. And she had found the SR number.
