I am fairly new to the Bentley World and want to set it up properly for my users who haven't used it at all. What I would like to do is setup the standards and DNG templates and other items that the end users will need on the server and have Bentley look there for these items.
Dimension Styles, Layers, Wall Configs, tags and callouts.
What I am lacking is what to look for and where in the configuration would I find the paths to point the others to? Is there a book or a white paper somewhere that I can refer to for this?
Thank you for the help
Great information here! Thanks, Paul. In order to try to keep down the server activity and open files, I used this:
_USTN_SYSTEMROOT = $(_USTN_INSTALLED_WORKSPACEROOT)system/
To point back to the system directory on the local drive, the content of which we NEVER modify, so might as well get them from C: as from a network drive. You might be using some .rsc and seed files from this location.
Mark Harrington: Great information here! Thanks, Paul. In order to try to keep down the server activity and open files, I used this: _USTN_SYSTEMROOT = $(_USTN_INSTALLED_WORKSPACEROOT)system/ To point back to the system directory on the local drive, the content of which we NEVER modify, so might as well get them from C: as from a network drive. You might be using some .rsc and seed files from this location.
Very good. I like it.
Hey Paul - are we finished with this thread?
David William Edwards
David, we are not finished. Just got busy and hadn't had time to get back to it.
Look for something up soon, compiling some of this thread and more.
Paul
