standard config files located on a server, what should I look for?
I am fairly new to the Bentley World and want to set it up properly for my users who haven't used it at all.  What I would like to do is setup the standards and DNG templates and other items that the end users will need on the server and have Bentley look there for these items.
Dimension Styles, Layers, Wall Configs, tags and callouts.
 What I am lacking is what to look for and where in the configuration would I find the paths to point the others to?  Is there a book or a white paper somewhere that I can refer to for this?
Thank you for the help
  • To be honest, I think you can take one step back and look at how you can set things up at the most basic level and then build to supply your vertical apps as well.
     Here's something I posted a while ago:
    The way my build works is very scalable.
    I have a cfg file in the appl directpry that helps me set my build location, it also allows me to have the build locally if users are travelling. This is controlled by login scripts and copied fresh to the users machine in each version of MS at login. It looks similar to:
    # Set SPS drive mappings
    build_drv = X:/
    P_DRIVE = P:/
    # Determine MicroStation Version
    # Set Version 85 to be the default
    MS_VER= MS85
    %if defined (_VERSION70)
    MS_VER = MS70
    %endif
    %if defined (_VERSION89)
    MS_VER = MS89
    %endif
    %if defined (_VERSION_8_11)
    MS_VER = MS811
    %endif
    #Set build locations
    %if exists (C:/standard/bentley/$(MS_VER)/Standards/.)
    _USTN_SITE = C:/standard/bentley/$(MS_VER)/Standards/
    %endif
    %if exists ($(build_drv)standard/bentley/$(MS_VER)/Standards/.)
    _USTN_SITE = $(build_drv)standard/bentley/$(MS_VER)/Standards/
    %endif
    #set client and project configs
    %if exists (c:/cad_var.cfg)
    %include c:/cad_var.cfg
    %endif
    _____________________________________________
    Under the 'standards' directory I now have my cfg files split to make it easier to debug and change. The directories under 'standards' are exactly the same and the install directories for MicroStation. This helps me and Bentley to sort issues.
    Part of the cfg files I have looks for cfg and pcf files in my working locations. This allows me to run the build as it is for all projects out of the box, but also allows me to append or overwrite using these cfg and pcf files. This is where the '%if exists' and '%include' come in. If these files have been created in the build locations, they are read and then the variables in them become part of the build.
    The out of the box build also uses the project and client to set reference paths and so on. It does mean having a good standard build, but it also means that anything outside of the build can be appended at the client\project config files.
    The cadvar.cfg files simply reads:
    Project=
    CLIENT=
    USERNAME=
    The only reason I've used batch files for this Company is that they won't purchase VB and I'll be buggered if I'll by it for them so I have to supply something they can look after if\when I move on. In the past I would use a small vb app started by a mate of mine that allows the user to pick a Client and Project read from a text file and also have links to the available apps. MS, BS and so on.
    The beauty about the vb app is that we also included a 'version' ext file in the project, if required, that allowed us to only make certain apps available once a Client and Project were selected. If done similar with the batch build, but to work around no vb I have added a version directory to the client and project builds that allows me to use a cfg file to help lock out particular version. It reads similar to:
    %if $(MS_VER)=='MS811'
    % error MicroStation Exiting, V8i not approved for this project. Please Use
    %endif
    The beauty of this is that, batch or vb, it is very flexibly and scalable without having to do too much work.
    How to deliver the build:
    http://communities.bentley.com/products/microstation/microstation_-_all_pre-v8_versions/microstation_-_all_pre-v8_versions_programming/f/163/t/21510.aspx
  • Isn't this a little "beyond" newby level? You've really got to break down what's required what's not, what we edit and where we put it. Even for someone who's been at this for 30 years, there's too much information, too many options and not enough basics (from what I can see.) Newby = new to MS / TF / BA... assume dumb Autocad user former Intergraph systems manager.
  • It might take a little reading, but it's a really good base for any beginner, and to be honest, none of this stuff is going to be super easy for any newby to the admin side of things.
    Basically, what ever the structure you build with, stick to the directory structure that Bentley use to make it easier to degug any issues you may have.
    Using:
    %endif
    %endif
    allows you to set a location on the network as your site build. If you have a look at the way MS is installed on your machine you then get an idea of what you need to replicate on the network.
    What this then means is that when MS starts up it will read any cfg file in the directory:
    This could be:
    X:\standard\Bentley\811\Standard\
    and so on.
    To start with you could hard code the paths in the cfg file you have in the appl directory until you work around the issues of setting a Client\Project etc. you could even just use a batch that copies in a new cfg file into the appl directory each time to set the build.
  • Thanks - I'll plow through this as best I can - It's starting to look familiar.
    "None of this is going to be super easy for any newby to the admin side of things." Bentley's marketing department needs to look very long and hard at that statement. Some of us are "having" to come to this cold because of no other reason than contract requirements. Now that we're trying to use the software our impression of it will go a long ways toward whether or not we'd recommend it to other users.
  • Plenty of people here able to help and give you other options.
