I am fairly new to the Bentley World and want to set it up properly for my users who haven't used it at all. What I would like to do is setup the standards and DNG templates and other items that the end users will need on the server and have Bentley look there for these items.
Dimension Styles, Layers, Wall Configs, tags and callouts.
What I am lacking is what to look for and where in the configuration would I find the paths to point the others to? Is there a book or a white paper somewhere that I can refer to for this?
Thank you for the help
When you say "a general user", do you mean you want one user that has a network workspace and one that has a local, or are you saying you want your entire workspace on the Network?
Jordan
As in the case with most things there are several ways to go about setting up a networked MicroStation workspace. Adding any of the building applications, of course, adds a whole new set of configuration variables and folder structures to deal with.
To help you out, I'd like to try and go step-by-step through what I would consider a simple set up.
If OK with you guys, instead of trying to explain it all in one long post, let's try it a few steps at a time.
I'll try to post daily and keep up with the thread here and answer questions as we go along.
Bear, feel free to chime in anytime on the process.
So, my first questions for anyone wanting to set this up is: What version of BA are you using? And, are you using any other building applications (BS, BBMS, BBES)?
