Walls not showing up in Place Wall Command.
Well, yesterday my company instaled the new Bentley Architecture V8i, Version 08.11.05.52. After instaling it, I started to add our walls to the Datagroup Catalog Editor. Well their showing up in the Datagroup but not in the pull down list in the Place Wall command. Now we did check everything off the Editable column except the Height. Trying to keep it to were people have to start using the company standard walls. Does anyone have any ideas on why our walls are showing up in the Datagroup Catalog Editor but not showing up on the Place Wall command? Also is there a way for us to set up the pull down for the walls to have under the single wall interior another folder that just holds our standard walls or does it all have to be one list?
Scott
