Hi all
Quick question, I hope... In Drawing Extraction Preferences there is a Forward/Reflected View Accuracy. If you set it to Tolerance, what units are you working in?
Nigel
Nige: it looks like it's in MU:SU, but the question becomes is it your Model Units, or your Extraction Seed File Units (which ideally would be the same, eh?)
Shawn
Hey Shawn! That's what I'm guessing too but I was hoping for official confirmation. I'm presuming it has to be the active model where the extraction is set up, but it could also be the reference group mode (?)
Any Bentley guys around to shed any light on this?
Since the calculations are performed in memory prior to outputting the extraction model, I'd imagine it's the source model units that matter; i.e., the model name displayed in the main DEM dialog. Of course, I'd hope that the working units are the same between the master file and the DEM seed file. :)
