It depends.
Many doors created by Bently are sweep elements across the entire frame. For that one you can't do anything.
Attached is a hollow metal door that allows you to set the head.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
