This is my first serious look at the Stair tool in BA. I am using it in a UK/European environment.I have had a look at us ncs dataset because I expect that is more feature complete but I am now using the 08.11.05.54 UK Uniclass as my base point with the intention of tweaking our customised in house dataset once I have learnt how it fits together
I have a choice to model the stairs in a conventional way - there a 4 stair cases two of which go up 7 storeys with differing storey height and two that are between two floors, which will
I am working on the basis that to set out and model the stairs would probablytake me 1-2 days and as such I should spend this time working out how the tool works so I can use it within our system - do people think this is realistic?
I am looking to get a better understanding of the configuration and control of the tool. So some questions:
rklaschka: 2 I am making a steel stair, which I have been advised that the stringers should be 300x20mm flats. There are no flats in any of the libraries. How do I create a stair of this type?
You will have to add a new steel member into your steel.xml file if you dont have one already. What i suggest you do is create a project related steel file and create it as part of the project data. Or just find a steel file that has a plate in it and copy it into your steel file.
Have a look at the file StructuralShapesTemplate.xls in the Workspace/triforma/Dataset_usNCS/data folder. It has all teh details you need to create your own Structural members.
Damon
Could you explain how the structural shapes template works? Or point me at the relevant bit of the manuals?
Robert
Thanks Damon,
I am also struggling to get this to function. Can somebody from Bentley elucidate? A step by step approach to getting this to work in Excel 2007 is what I need.
The toolbox Damon has described does not appear for me. Also some indication of which are required fields in the shapes tabs would be handy too.
1) Click on the Excel 'Office' button - the "orb" at the upper left - and then click on the Excel Options button at the bottom of the pop-up menu 2) From the Popular category, under 'Top options for working with Excel', check the 'Show Developer tab in the Ribbon' option then click OK. 3) Open the spreadsheet, then switch to the 'Developer' tab enabled above 4) Click on the 'Macro Security' button and from the Trust Center dialog check "Enable all macros (not recommended, potentially dangerous code can run)" 5) Add the desired values to each tab as needed 6) Once complete, click on the Export button in the XML section (Developer tab) 7) The XML file you've just created should load up in Structural
I just tried a quick test using this process, and was able to place the sections I created. Whether this is the "right" way I cannot say, but it seemed to work OK!
Excellent Steve - thanks for this useful commentary.
It worked for me too.
All I need to do now is get my stringers mitring together properly and I'll be laughing - should I file this as a CR?
No problem at all, Robert. I think I'll add this info to our online KnowledgeBase for future use!
Regarding the stringers... I haven't read that part in any detail, but yes, I would recommed taking the CR route via a service ticket. At least that way it's officially in our system.
Ah - I have a solution to the stringer mitering problem! Very straight forward flick to plan view and the heads up display gives me control of the dims I need access to.
I guess that officially means I can do exactly what I need to. Nice.
