Best Practices - Using Building Views in Bentley Architecture
Two documents have been posted that identify Best Practices - Using Building Views in Bentley Architecture. Note that you have to be a member of the Building Solutions (BIM) community to access them. They are:
Each title above is a link to the document. There are a variety of ways to set up and use Building Views. Here you will find our descriptions of major pieces of functionality as well as recommended steps and work flows to achieve the best and fastest results for producing drawings with the new Building Views, which are built on the Dynamic View technology within MicroStation.
Comments and ideas are welcomed.  We will continue to add to each and include additional documents in the future.
Sincerely,
Steve Stevens
Product Manager - Bentley Architecture
