<Thomas Voghera> wrote in message news:98479@communities.bentley.com...If I have created a BV - how do I change its location in Z? Like the DEM "move selected section defs". -- regards / Thomas V http://communities.bentley.com/Products/Building/Building_Analysis___Design/f/5917/t/43950.aspx
regards / Thomas Voghera
Correct... You need to be able to select the Clip Volume first in order to display the section marker for editing. I've never actually tried that through a reference, but I'm guessing from your post that it did not work. ;-)
